I've replaced the toner and the fuser but am still having a fading problems on everything I print. I use this for receipts and invoices on 8x11 from bins 1 & 2. There is repeted heavy usage at the top of the page where I am having the fading issue. Can anyone help me with any suggestions? There are also short streak lines on the right edge.
SHARP MX-M753N PRINT FADING, REPLACED TONER & FUSER
What is the meter on the machine? I am going to agree with others and say DV would be what to look at. When the dv starts to get low, you will get a diagonal pattern on prints, we call it "barber pole" pattern as it kinda looks like an old school barber pole. Can you post an example of the output?
Failing to plan is planning to fail!!!Comment
👍 1Comment
