SHARP MX-452N factory reset
  • bigdormouse
    • Mar 2022
    • 3
    How to factory reset SHARP MX-452N ?
    Factory reset point from printer panel and from web page - both don't work (logged in with admin password).
  • ZachHarbour
    • Jun 2021
    • 23
    Re: SHARP MX-452N factory reset
    You went into the system setting -> security security settings -> and ran the end of lease option? If that didn't work you could probably do a HDD format and that would clear all previous information and settings set onto the machine. Not sure if that will be completely necessary but it might be a last resort kind of thing.
    Best of luck!
    Zachary Harbour
    Hogland Office Works
    zach@hoglandcopiers.com
    • bigdormouse
      • Mar 2022
      • 3
      BOTH:
      Browser, printer ip, admin logon
      System settings, Storing/Calling of System Settings, Restore Factory Defaults, Execute
      OR
      Printer display, System settings, admin logon
      don't work
      (strange - why Sharp created this if this don't work)
      "ran the end of lease option" Hmmm, didn't found that item
      HDD format...? Maybe, i'm not sure because... where printer software is stored on hdd or somewhere else.
      • mloudy
        • Oct 2015
        • 784
        System Settings
        Admin Password (might be admin)
        OK
        OK
        Security Settings
        Data Clearance Settings
        You should see all kinds of options to clear things out
        • bigdormouse
          • Mar 2022
          • 3
          Originally posted by mloudy
          System Settings
          OK
          OK
          Security Settings
          No such option
          • mloudy
            • Oct 2015
            • 784
            You may need to just go to the web page, login in as admin and begin clear everything out manually.
            THen print out a 22-6 and find the soft switches that are still highlighted in black and set them to the opposite of what they are.
