MX-5070 Display dead after incorect network settings
  • Harald
    • Mar 2022
    • 2
    [Dead] MX-5070 Display dead after incorect network settings
    Hello, I have a problem with a used Sharp MX-5070. The device worked perfectly - then I changed the port for http from 80 to 443. Then the Sharp asked me to restart it - since then it has stuck when starting, switches to black after the please wait screen and no longer reacts to any keys.
    I've tried a few things - is there a way to factory reset the device without using the screen? button e.g. or with a firmware update? Please help me! Thanks!
    Please be tolerante about my worse english ;-)
    green power Led is lit and the home button light is also on!
  • leo34staffs
    copierman
    • Aug 2007
    • 503
    Re: MX-5070 Display dead after incorect network settings
    You could try the emergency firmware update procedure (dip switch on main board) and prepare firmware on root of usb stick.
    Networking skills are advantageous but use of a 3m vacuum cleaner is essential
    • mloudy
      • Oct 2015
      • 791
      mSata might be currupted but not from the newtork changes. If the copier has not had the power cycled in a long time they will sometimes do what you are describing after a power cycle. Either install a new mSata from Sharp or find a clean copy of a Sharp mSata for that model and copy it to the mSata in the 5070. This should bring it back to life but many setting will be lost.
      • Harald
        • Mar 2022
        • 2
        Thank you all! For me the update of the firmware works!
        Only one question is there at the moment -former i try to clear the memory by removing the CR2032 - now i have the Code:U1-01 - how could i clear that?
        • mloudy
          • Oct 2015
          • 791
          Sim 13
