Faded On AR 161 Panther series
  • Johsel
    • Mar 2009
    • 9
    Gud Day!!! Can anyone help me with this, The machine model was AR161, Problem was copy fading and when I look at the drum it seems that the developer stick on it and when I checked the waste toner pipe, I saw developer on it which is something that shoud'nt happen. Can anyone site was is the theory behind this and what its causes?? I need an intelligent suggestion. Thanks!!!!!
  • xeroxsharp
    • Nov 2008
    • 270
    If everything else works OK, you need new drum,drum blade and developer. Model 161 is ok
    • lky1978
      • Mar 2009
      • 483
      better you check the developing unit cleaning seal, clean main corona unit
      • bilyahn
        • Dec 2006
        • 1470
        Sometimes when you take the drum unit apart the charge unit will not be put back in properly (there is a metal flange on the charge unit the fits into a guide in the drum unit). My boss did this twice and the conditions you stated are very similar to what he experienced.
        Good luck.
        Bil
          • 23006
          I agree with lky1978. The top developer cover can warp. The upper developer seal then scoops of toner and developer from the mag roller leaving light areas.
          Sometimes replacing the rubber seal is enough. Other times the developing unit must be changed if the top cover warps too close. =^..^=
          • paquinta
            Limpia muy bien la unidad de drum y su corona. Pueden estar desgastados los sellos del espiral de developer o simplemente la unidad no fue balanceada antes de reinstalar.
