sharp ARM-155
  • DINGO
    • 661
    sharp ARM-155
  • OMD-227
    Should be a fuser problem. Our B/W copier guys are always changing the fuser units on those machines. Forever complaints..... aahh well. Lucky for me I dont touch them at all.
    Upper Roller loses its coating, toner sticks to the roller as a faint ghosting image.
    • DINGO
      • 661
      ok
      thanks, yes, y look to the upper fuser roller and seems me good, !!!!but y think to that y must replac e it.
      thanks again, y apreciat very much yours opinion.
      • vlad_robas
        • Oct 2006
        • 225
        this machines have fuser problems and might not go even 25k with one
        • xeroxsharp
          • Nov 2008
          • 270
          Xerox XD104 has the same fusser unit and works better.
          • Johsel
            • Mar 2009
            • 9
            Hey!! what wazza said was true, I've encountered so much of that here in the philippines and the problem was solve by replacing the upper heat roller(fusing roller coated w/ teflon). But if you are verry sure that the upper heat roller was good, try to look at the drum cleaning blade, sometimes when it is soft enough and unable to clean the drum. so residual toner was remain on the next rotaion w/c causes a double image. I hope I gave some idea.
            • DINGO
              • 661
              re
              ok
              But the problem in my case is in the fusion, y think that y must change the upper fusere roller.
              thanks
