SHARP MX3570V
  • Tech2002
    • Aug 2008
    • 334
    #31
    Re: SHARP MX3570V
    Originally posted by branjake
    Try the clutch in the fuser drive unit, that clutch moves the transfer roller. We just had this issue.
    Was the Print/Copy issue an occasional issue or was it print/copy light all the time?
    • branjake
      • May 2016
      • 7
      #32
      Re: SHARP MX3570V
      It was occasional, was starting to happen alot more before he tried the clutch. The clutch he took out was harder to turn then normal.
      • Sage632
        • Jul 2019
        • 45
        #33
        Re: SHARP MX3570V
        *2ndary xfer unit
        • doyvid
          • Aug 2019
          • 56
          #34
          Re: SHARP MX3570V
          Any solution yet?
          • Tech2002
            • Aug 2008
            • 334
            #35
            Re: SHARP MX3570V
            Originally posted by doyvid
            Any solution yet?
            Unfortunately no solution yet. Their IT changed the Print Driver from Server
            Based to a Computer Install. Doing this is not a bad thing to see if it
            would cure the issue - but, when I have run a SIMMS Report from the copier,
            I have had the same print issue.
            I am leaning towards something mechanical rather than a Board. The
            issue is intermittent which makes this really difficult to find and arrest.
            Thanks for the inquiry.
            • branjake
              • May 2016
              • 7
              #36
              Re: SHARP MX3570V
              Originally posted by Sage632
              *2ndary xfer unit
              The clutch that moves the Secondary transfer roller is located in the fuser drive unit, we changed it and it fixed the issue.
              • Tech2002
                • Aug 2008
                • 334
                #37
                Re: SHARP MX3570V
                What made you think to change the Fuser Drive? Did you try other repairs before that change?
                Did you have the issue with both Printing and Copying? Single Sided and Double Sided?
                • cutdog
                  • Jul 2015
                  • 5
                  #38
                  Re: SHARP MX3570V
                  I'm the Tech who changed the clutch in the field that Branjake referred to, The issue was on copy and print, and it was very intermittent. the clutch is located at the bottom of the fuser drive unit, and it's sole purpose is to move the secondary transfer roller to the print position. Section 66 part number 25 in the PG.
                  • Tech2002
                    • Aug 2008
                    • 334
                    #39
                    Re: SHARP MX3570V
                    Thanks for the detail on that. I am waiting on the power source. I am finding out
                    that there may have been an issue with the outlet. I have an Innovolt on the system
                    and will be able to get a read on the power from the stored power information.
                    How did you get to finding it was the clutch? My issue with this is there are no error codes.
                    • cutdog
                      • Jul 2015
                      • 5
                      #40
                      Re: SHARP MX3570V
                      I actually had another machine with the same problem again today. A 5070v. After trying a few different things with no luck, I panic stopped the machine and noticed the image on the tc1 belt looked good. I also had no error codes on both machines I had recently. Testing in sim 6 shows it changes state. I'm not sure why it never coded. Changing that clutch took care of the issue. 2nd one within a month, I'll be on the lookout for more.
                      • cutdog
                        • Jul 2015
                        • 5
                        #41
                        Re: SHARP MX3570V
                        FYI the 2nd tc clutch that's in the fuser drive is the same as the 2 primary separation clutches on back of the main drive unit.
                        • Sage632
                          • Jul 2019
                          • 45
                          #42
                          Re: SHARP MX3570V
                          Only on print jobs? Yes.
                          What about copy jobs? I've been told no.
                          If it happens on prints, it will also happen on copies (provided it's in the equipment)
                          If it happens on copies only, that tells you it's in the optics.
                          Same print engine is used for copies and prints.
                          • Tech2002
                            • Aug 2008
                            • 334
                            #43
                            Re: SHARP MX3570V
                            And the answer is - Fuser Gear Clutch. It was that simple - but it always is when you look back after the fix. I want to thank everyone's input. This was one repair that had lend itself to multiple possibilities. And it didn't help that the issue was intermittent with no codes.
                            I hope if anyone has never had this issue that this helps them focus in on where maybe to look first. It made sense that it was a Clutch that would have failed. I had a discussion with a Sharp Executive a few years ago when this series copier came out. He told me one of the reasons for upgrading the Units was because of the electronics - they were not working well, that was the electronics weren't working well. They were having larger failures then usual. It was about the wiring - the connectors.
                            Again, My Thanks to All!!
                            • jp74msj55
                              • Oct 2014
                              • 146
                              #44
                              Re: SHARP MX3570V
                              When I changed out the Primary Transfer it was the whole unit.
                              I forgot to add that I have done a 61-1 Laser Check - Good
                              Firmware has been updated to most resent.
                              The issue I have described intermittent. It appears to only act up as described after it has
                              been working long runs. Plus I tried most of the suggestion recommended to me - very
                              appreciated.
                              Because the the long run and problem scenario I decided to change out the Transfer Control PWB.
                              It was the heat thing that made me to look in this direction. I've got it replaced and it is a wait
                              and see.
                              One of the up ticks with the replacement board the colors, from a copy to a copy - those color copies popped!
                              Just that alone made me think it was a good thing to have specifically changed out that board.
                              I'm not out of the woods yet, but will update in a week or so - it shouldn't take too long to see
                              a positive or negative final results.
                              I sincerely appreciate everyone's input!!!
                              Have you tried Sim 64-4 and change to 3 to check individual colors????
                              • Tech2002
                                • Aug 2008
                                • 334
                                #45
                                Re: SHARP MX3570V
                                Originally posted by JLSam
                                The master of the obvious strikes again!
                                Appreciate your input!
