SHARP MX3570V
  • Tech2002
    • Aug 2008
    • 334
    SHARP MX3570V
    I am having an issue while printing from the computer.
    The print comes out very faint then appears to clear
    up where the images are fine. I'm thinking it might be
    the lower heat roller lamp.
    The Blk DV Unit and the Drum and Blade have been updated in the
    last 6-months or so. And the fuser has been updated.
    I can't say I have have ever seen this happen before. I'm not out at
    the client's office yet. They have some sick people that are out and they
    wanted me to come in at the end of the wee to fix the issue.
    Any suggestions greatly appreciated.
  • mansart
    • 852
    Re: SHARP MX3570V
    Only on print jobs?
    What about copy jobs?
      • 22990
      Re: SHARP MX3570V
      A sample might be helpful. =^..^=
      • JLSam
        • Jun 2015
        • 605
        Re: SHARP MX3570V
        The master of the obvious strikes again!
        • Tech2002
          • Aug 2008
          • 334
          Re: SHARP MX3570V
          Originally posted by mansart
          Only on print jobs?
          I was told in an email that this happens only when they print.
          • Tech2002
            • Aug 2008
            • 334
            Re: SHARP MX3570V
            Funny thing of it is, I do know the manual - I just haven't seen this happen before. I thought I'd marry up to what I thought it might be. Thanks any way.
            • Tech2002
              • Aug 2008
              • 334
              Re: SHARP MX3570V
              Only on print jobs? Yes.
              What about copy jobs? I've been told no.
                • 22990
                Re: SHARP MX3570V
                That lower part of the window is called the signature line. It's exactly the same on every post. I wrote it 10 or so years ago (not just for you), but it applies to everybody I think.
                I don't see how anybody can evaluate an image quality issue, without a sample. =^..^=
                • mansart
                  • 852
                  Re: SHARP MX3570V
                  The actual mechanics of paper xport, placing image and fusing image on paper are the same for both copy and print. I'm not saying its impossible, but highly unlikely that this is a fuser issue.
                  Are the light images isolated to a single app?
                  What does an internal print look like?
                  What about print a PDF from USB ? Same result?
                  • Tech2002
                    • Aug 2008
                    • 334
                    Re: SHARP MX3570V
                    I'd show a sample but the clients info is on that sample.
                    I have been sick and won't be out physically to the client until probably tomorrow.
                    I'll have an answer then. Thanks!
                    • Tech2002
                      • Aug 2008
                      • 334
                      Re: SHARP MX3570V
                      I have found out the following since I started this thread -
                      Client is having the imaging issues whether printing or copying.
                      Last week they were doing a lot of printing for a conference they
                      were attending and did not notice the copy side of the machine
                      was affected, too.
                      I have done the following -
                      67-33 - Good Values
                      67-34 - Good
                      52-22 - All Good
                      All Drums. Blades, and MC's changed within the last month
                      Fuser has been Updated
                      Changed out Primary Transfer
                      I have an attachment showing the distorted imaging issue.
                      I don't know if I got that right.
                      • mansart
                        • 852
                        • Tech2002
                          • Aug 2008
                          • 334
                          Re: SHARP MX3570V
                          Thanks for the input. I'll hopefully know more tomorrow Monday the latest.
                          • Tech2002
                            • Aug 2008
                            • 334
                            Re: SHARP MX3570V
                            Re: SHARP MX3570V
                            was affected, too.
                            67-33 - Good Values
                            67-34 - Good
                            52-22 - All Good
                            • mansart
                              • 852
