disable fax
  • boutn
    • Jun 2016
    • 547
    disable fax
    Hello,
    Is it possible to disable Fax on the MXC304W?
    Like completely disable it, not only delete the shortcut on the homepage
  • onetek
    • 318
    Re: disable fax
    Remove back cover , disconnect fax , done.
    • mansart
      • 852
      Re: disable fax
      I'm not a betting man, but if I were, I would bet on the horse named "Error Code"
      I would assume that just unplugging fax board would result in some type of code.
      F6-00 most likely.
      • boutn
        • Jun 2016
        • 547
        Re: disable fax
        F6-00 most likely.
        • mansart
          • 852
          Re: disable fax
          I tried this on a MXM455 after seeing your post. Initially looks like it will work but after about 10 minutes will throw F6-00
          • boutn
            • Jun 2016
            • 547
            Re: disable fax
            yep, F6-00 it is
            • bilyahn
              • Dec 2006
              • 1470
              Re: disable fax
              You should be able to disable the fax in system settings/device settings or is this a lexmark/sharp
              Good luck
              Bil
              • onetek
                • 318
                Re: disable fax
                My bad, the copier in our shop with a disconnected fax board is a MX-C407F. No F6-00 on this one, just error 900 popping after sometime. We disconnected the fax to make sure error 900 was not from fax board.... Fax disabled in settings too.
