AR-161 TD cartridge trouble
  • sarcopy
    • Aug 2025
    hello there
    Anyone had problems with the TD cartridge warning light staying on after a new cartridge is replaced on this model?
    Here's a bit of the story with this one: both TD cartridge and the drum cartridge indicator lights were on, and machine was used until it would no longer make copies. Replaced both cartridges, the drum indicator light did go off, but upon startup the TD light goes off, machine runs for 2-3 minutes, then stops with TD indicator blinking. Have already cleared developing counter 42-1.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1897
    Replace the toner motor
    More than likely a broken shaft on the toner motor. Pull out the cartridge & the white gear is probably laying in there. The first production models had a plastic shaft with a pin through it. It would usually break after putting a new cartridge in, as the full cart. is a lot harder to turn. It's a bitch to replace unless you've done about 50 of them like I have.
    Good luck.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • sarcopy
      thank you--issue solved
      In the process of checking the plastic drive gear, which was still intact (I'd replaced one of these a couple of years ago), found that the gear on the cartridge was very sticky. Loosened it up with a few turns and presto!
      Much appreciated
