AR M160 Registration Sensor ?
  • mrfuser
    • 1617
    Anyone know a part number for this old beast? Its the sensor that detects the paper as it gets to the registration roller. Paper In Sensor I believe. Just can't find the part number.
    Sharp AR M160
    Thanks all!
    K
  • Prints Charming
    • Aug 2019
    • 189
    Re: AR M160 Registration Sensor ?
    Parts Guide Section 13 Base Plate Unit.
    PS Unit Front Actuator.
    Sensor 61 is VHPGP1S73P+-1
    Actuator 39 is MLEVP0091QSZZ
    • mrfuser
      • 1617
      Thank you for the help!
      • mrfuser
        • 1617
        Ok replaced feed sensor and still registration roller does not activate. Everything looks ok on the registration rear shaft, spring, gear, etc. any ideas?
        • OlliK1969
          • Nov 2016
          • 310
          Hi
          If you already have it, there is a broken part in the registration clutch.
          Test it to see if you can turn the registration manually (with the green button in front) and if it really turns.
          • copiertec
            • Jan 2016
            • 2205
            solenoid? Is it firing?
            • mrfuser
              • 1617
              yes it does turn
              Originally posted by OlliK1969
              Hi
              • mrfuser
                • 1617
                You mean the small solenoid with the white arm against the registration shaft?
