Sharp MX101N - 2nd transfer belt not turning.
  • rdyjnkns
    • 135
    [Jamming] Sharp MX101N - 2nd transfer belt not turning.
    The 2nd transfer belt is not turning which is causing an accordion jam. I marked both the belt and the drive gear and neither the belt or the gear is turning. I believe it could be the motor, but I welcome a second opinion. Also if there is a way to perform a check of the motor in the simulation mode, that information would be deeply appreciated.
  • copiertec
    • Jan 2016
    • 2191
    Re: Sharp MX101N - 2nd transfer belt not turning.
    Is the Model an MX101N?
    • rdyjnkns
      • 135
      Sorry, MX-4101N. Wish I could delete and start again.
      • MoochPage
        • Jul 2019
        • 58
        I am not sure if there is a way in simulations to run just the secondary belt. If I were on a machine with your described problem I would check the primary transfer belt drive gear on the primary transfer belt. One of the models it would crack and not rotate properly and cause jams like you are saying. Need to take the gear off and look at the inside of it a pin would just spin on the gear.
        • rdyjnkns
          • 135
          Thank you. I will take a look at that.
          • copiertec
            • Jan 2016
            • 2191
            I know the belts on those models can stretch out and not turn, but you said the gear is not turning so there is another issue causing the issue perhaps a motor.
            • onetek
              • 318
              Like Copiertec said, its probably stretched and not turning. In a pinch, you can just cut the belt of and use the machine for a few days without jams. (done that many times).Its driven by the same gear that drives the #1 T-belt. Also what MoochPage said is spot on. I always carry a spare gear with me .
              • copiertec
                • Jan 2016
                • 2191
                The drive gear on the primary transfer unit always stripped out at the pin.
                • rdyjnkns
                  • 135
                  I want to thank all of you for your assistance. I will be seeing the customer in the morning (they open at 6:00 PM PST). At least, I will be the traffic on the US15 North. I will keep you informed.
                  • rdyjnkns
                    • 135
                    Greetings. Good news - the problem has been resolved. The gear that drives the primary transfer belt was missing its screw. Bad news - now I have the LA-04 code which has to do with the primary belt assembly not seating correctly. I cleaned both the sensor and installed the assembly - no joy. I was able to run SIM 06-03 without an error. Upon reboot the belt runs smoothly but still get the error. Any suggestions would be deeply appreciated. If need be, I can start another thread.
                    • OlliK1969
                      • Nov 2016
                      • 310
                      Hi
                      L4-04 means Developer Motor trouble BK
                      • MoochPage
                        • Jul 2019
                        • 58
                        I would check to make sure you don't have a flipped blade on the black drum
                        • rdyjnkns
                          • 135
                          Originally posted by OlliK1969
                          Hi
                          Thanks OlliK1969. The code changed to L4-06 which is the Primary Transfer Belt Assembly clutch (see attached photo). Sharp MX4101n PTA Clutch.jpg
                          • MoochPage
                            • Jul 2019
                            • 58
                            I would replace that clutch it looks terrible!
                            Originally posted by rdyjnkns
                            Thanks OlliK1969. The code changed to L4-06 which is the Primary Transfer Belt Assembly clutch (see attached photo). [ATTACH=CONFIG]53583[/ATTACH]
                            • rdyjnkns
                              • 135
                              I will, MoochPage. But something tells me it is going to be a bear to remove the old one. And there are no instructions in the service manual. But I got to this point. Just have to take photos.
