Re: Sharp MX4101N - 2nd transfer belt not turning.
Greeting fellow technicians. I have received the new primary transfer belt assembly clutch and I believe the best way to perform the repair is to remove the whole drive section. I have attached a copy of the instructions from the service manual. Although it appears pretty straight forward and simple, could it be that simple? Your input would be deeply appreciated, especially if you have done this before. Thanks.
