Want To Ask ( Remove paper background color to transparent ) MX-M1206
  • abangcopier
    • Nov 2020
    • 3
    Hi All,
    Currently I got a government customer which require a color paper (Original) to copy into another color paper. But the output paper still show shadow background from original one.
    It is possible to MX-M1206 to remove completely the shadow rectangle behind the text? Even I ask the technical from Sharp Principle HQ, still don't have any answer from them.
    • 22995
    Re: Want To Ask ( Remove paper background color to transparent ) MX-M1206
    I'm going to go out on a limb, and say that I don't think that it's possible to entirely remove a solid red background without also removing most of the text. =^..^=
    • JLSam
      • Jun 2015
      • 605
      Yes it is possible. IF this is from a Copy, then, I suggest simply trying to use "Suppress background" feature and using "Text" only as exposure.
      You can even save it as default, or as a preset.
