MXC357F - 126.11A error code
  • kdr363
    • Apr 2019
    • 63
    We finally tried a couple Sharp-marks. The first one throws this error intermittently when waking from sleep mode. The hotline's suggestion was to request an RA. The next machine that came in does the same thing, errors when waking from sleep mode. We tried resetting connectors and different outlets. Currently trying a line conditioner just for the heck of it. Anyone had this?
  • mloudy
    • Oct 2015
    • 774
    Re: MXC357F - 126.11A error code
    Had this error on a XC4140 once and replaced the LVPS. I dobut you have two machines in a row with a bad LVPS though.
    We have only sold one of these as we were not impressed with the design. The MX-C407F is a huge upgrade for less than $300 more. If space is limited though the MX-C407F may not fit.
    The error relates to the fuser but the description is "Line frequency has gone outside the operating range."
    I have a feeling the hotline does not like troubleshooting Lexmarks and RA is their most common fix.
    • mojorolla
      The Wolf
      • 2583
      I was talking to a friend, he had three Lexsharts he tried to get an RA on, they told him to keep them, and they would ship new ones!
      How poor and cheaply made is the product if they don't even want them back? So glad I don't have to deal with Sharp anymore.
      • Tonersniffer
        • Nov 2012
        • 74
        Same problem here. I have 2 MXC357F. Wish me luck! Line condition I used didn't help.
        • chubblies
          • Jun 2011
          • 154
          A line conditioner won't adjust the AC frequency. Are you sure it isn't a main input issue if you have had 2x printers doing the same fault? The main power has the frequency set so it may be that the machines are detecting a poor sinewave, and this is the machine just detecting that.
          • mloudy
            • Oct 2015
            • 774
            If Sharp lets you guys keep these machiens after an RA I would apply firmware updates as they are released in the future. They might start working. I think the Sharpmarks are currently 3 levels behind their Lexmark counterpart. Lexmark firmware updates fix loads of issues.
            • onetek
              • 318
              On a mxc407f , while waiting for a main board to fix a random firmware error 900, I figured that I would try the latest firmware from Lexmark. All went smooth, (but it did not fix the error). We have about 20 in the field, at least 3 are giving random 621.01a codes. Line voltage ok, fusers and connections ok, power supply ok.....so........
              • mloudy
                • Oct 2015
                • 774
                I have not been brave enough to try to update a Sharpmark with Lexmark firmware.
                There was a new firmware from Lexmark released a few weeks ago but it was taken down quickly. It was 081.205
                Just about all of their updates address 900 errors.
                Fuser errors on this series is the main issue we see.
