Sharp MX 3110 N Power indicator shows yellow and will not power up.
  • EasyRider
    • Jan 2015
    • 87
    #16
    Re: Sharp MX 3110 N Power indicator shows yellow and will not power up.
    HDD Raw Copy. That and the SD file are what you need.
    • patterson70
      • May 2010
      • 597
      #17
      Thank you but I amnot finding the correct site to download it. There are several. EaseUS ToDo Backup is not working so far.
      • EasyRider
        • Jan 2015
        • 87
        #18
        This should get you started... HDDGURU: HDD Raw Copy Tool
        • patterson70
          • May 2010
          • 597
          #19
          Thank you but I already downloaded EasyUS ToDo Backup (The $41 paid version because the free would not work) and it fails when trying to clone the Sharp SD Card. I verified it does work with another SD Card I have - so now I assume the Sharp SD Card is corrupted too much for copying. Could you direct me as to what to do now? Purchase the Card with the firmware on it somewhere?
          • mloudy
            • Oct 2015
            • 776
            #20
            You need part# VHI0MFP00237C
            • patterson70
              • May 2010
              • 597
              #21
              Thank you, can you give me any other details? I cannot find it anywhere on the web.
              • mloudy
                • Oct 2015
                • 776
                #22
                You would need to buy it from a Sharp Dealer.
                I have a clean image of a MX-3110N SD card I could send to you. Copy that to a new Sd card. Buy a good quality 16GB SD card from either Amazon or eBay. I think you only need 2G but we use 16GB across the board.
                • chubblies
                  • Jun 2011
                  • 154
                  #23
                  Here is an image file for a MX2610 which I believe is the same image file. Use HDD raw copy tool to image it onto the SD card.
                  • lky1978
                    • Mar 2009
                    • 482
                    #24
                    https://www.dropbox.com/s/ii31m95mws...610N.imgc?dl=0
                    hi chubblies, do you have image file for MX-6240N?
                    Sent from my M2102J20SG using Tapatalk
                    • chubblies
                      • Jun 2011
                      • 154
                      #25
                      Nope sorry
                      • Matoku
                        • 173
                        #26
                        Hello, not sure what I am looking at needing to be replaced: Power Supply or a Board, or something else?
                        The power indicator light will not go from yellow to green. Stuck in a warm-up stage. The touch-screen does not come on either. All of the doors and trays are closed.
                        Hi Patterson, do you manage to solved this problem on your MX3110?
                        • patterson70
                          • May 2010
                          • 597
                          #27
                          No not yet, i had trouble trying to retrieve the file and have been meaning to try again tomorrow. I would rather just buy the card with the software already on it is anyone has that available?
                          • mloudy
                            • Oct 2015
                            • 776
                            #28
                            Send me your mailing address and I will send you one. If it works $15 plus postage.
                            • patterson70
                              • May 2010
                              • 597
                              #29
                              Just did via pm. I appreciate your help and everyone else's.
                              • patterson70
                                • May 2010
                                • 597
                                #30
                                Back again after a very helpful and kind Tech here tried to assist - but unfortunately no success.
                                He provided a known and tested SD card to me vial mail since i could not get the Raw Copy Tool to work.
                                However that did not resolve the problem.
                                I then replaced the HDD with a new Western Digital 160GB but no success with that either. (He sent me the firmware in case it was needed)
                                He has suggested I go back to this forum to get any other advice.
                                Previously Iky1978, a Tech here, recommended the Power Supply could be the culprit.
                                I'm just asking before I do that - does this look like the most likely route to anyone else as well? Thanks again to all.
                                As a recap - on main poser on I get power enough to move the scanner and run the fans - and the sleep light is on, but no display and no button on the display does anything. Will not print anything either - tried that.
