Error code F2-64 with Sharp MX-5070N
  • minhphu511
    • Sep 2020
    • 4
    [Error Code] Error code F2-64 with Sharp MX-5070N
    Hi everyone, good day to you. I'm facing a hard trouble. My MX-5070N occures error code F2-64. I did some step below :
    - change new original toner cartridge
    - cleaning toner hopper and sensor in hopper
    after few day, this trouble appears again.
    Please kindly teach me how to solve this trouble forever
  • driving lots of miles
    • Jun 2016
    • 397
    Re: Error code F2-64 with Sharp MX-5070N
    It is likely going to be the toner supply motor or the gears in the unit. We have had to replace the drive motor a couple of times on different machines.
    • minhphu511
      • Sep 2020
      • 4
      Dear Mr,
      I checked toner supply motor runs normally by sim 10-1, and the gear in the unit also good. Many thanks for your reply.
      • mloudy
        • Oct 2015
        • 775
        Most of the time replacing the black DV unit and with fresh DV fixes this problem. Make sure fimrware is current also.
        I did find notes that a tech changed a middle toner hopper unit once to get a F2-64 to go away on a MX-5071. This customer also had bad power so we made them to run a didicated line.
        • ctuinstra
          • Apr 2011
          • 49
          Dear Mr,
          I've done the same thing and thought it was good. It wasn't until I tried one of the other colors and notice a very audible difference in it and then swapped the two and the problem moved. Try the motor and gear unit. Sometime we talk ourselves out of the solution.
          • boutn
            • Jun 2016
            • 540
            We had one of these recently...
            Swapped the toner motor, hopper assy, DVbox, still got F2-64
            Turned out to be the PCU PWB
