Sharp mx 3061 e7 03 hard disk
  • monkees
    • Jan 2011
    • 40
    [Error Code] Sharp mx 3061 e7 03 hard disk
    Hy guys
    I replaced an original ( sharp ) hdd with a compatible (with the same characteristics) one with the same features but it gives me an error code
    it is possible to install a non original hd on sharp machines?
    thank
  • mansart
    • 852
    Re: Sharp mx 3061 e7 03 hard disk
    non-original work here in the U.S.
    have you tried a 62-1?
    • mloudy
      • Oct 2015
      • 773
      Yes you can use an off the shelf HDD. You likely need to install watermark firmware if you haven't.
      • monkees
        • Jan 2011
        • 40
        Thanks for the replies
        i installed the watermark firmware
        sim 62 1 result NG
        hard disk I bought it with the same code as the original in a **** n
        it's not compatible ?
        • ron67601
          I use MQ01ABF032 Toshiba 320GB and it always works. Might be because the one you have pictured is a 500GB HDD. Hope you get it going. Good Luck.
