MX-3060V - RSPF SSPD3_N Jam
  • Sigma
    • Jan 2022
    • 3
    [Jamming] MX-3060V - RSPF SSPD3_N Jam
    Hello,
    I have a machine that jams everytime with the error code SPPD3_N
    But only when I try to do a black&white copy
    The copy worked fine when I used the missfeed disable in SIM 7-1
    If I select color copy then it works without a problem
    The firware is the latest version
    What could be the cause of this?
    If it was the SPPD3 sensor it would jam even in color, right?
    (Sorry I'm kinda new to copier maintenance, so I'm not sure what to do/check)
    Thank you in advance
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: MX-3060V - RSPF SSPD3_N Jam
    Does it jam every sheet or intermittent?
    How many pages have been thru the feeder?
    As you pointed out the sensor is probably good because it works in color scanning. But since the copy speed is faster in bw mode, I'd look at the transport clutch.
    • Blizzoo
      • Aug 2013
      • 611
      I have very limited experience with Sharp. If that sensor have a actuator type sensor then may be a problem with the returning speed after the BW paper passes over?
      • Prints Charming
        • Aug 2019
        • 189
        Copy mode is almost twice as fast for BW compared to Color on this document feeder (80 vs 41 ppm), but Scan mode is the same speed for both BW and Color (80 ppm).
        Run some Scan to HDD tests instead of copy tests. If you still have SPPD3 jams in Scan Mode on both BW and Color, you've either got a transport clutch issue or slow return sensor actuator spring. Both of these causes would be negated with Jam Disable mode turned on as it's not a physical blockage of the paper pathway.
        If a set of 50 sheets passing through the document feeder evenly & without hesitation or stalling/buckling (when Jam Disable mode is activated) then it would be safe to say the transport clutch is OK. Lean more towards drive belt tension or slow sensor actuator. To access SPPD3 sensor requires the document feeder to be dismantled quite significantly, but it's very easy.
        • Sigma
          • Jan 2022
          • 3
          It jams at the very first page
          I'll try that when I go back to the client
          Thank you for the suggestions
