MX-M4070 POLYGON
+ More Options
Posts
  • bigdaddyooo
    • Dec 2014
    • 212
    MX-M4070 POLYGON
    I have an MX-M4070 that when the polygon fires up it sounds like an F-16 starting its engine. Has anyone else experienced this? Im going to order a new one but my God, is it loud.
    Are you the police? "No ma'am, were musicians"
  • tmw
    • Dec 2013
    • 260
    Re: MX-M4070 POLYGON
    I don't remember Sharps doing it, but other models, (toshiba, HP) definitely. Recently had to replace a Sharp laser for an intermittent code, but no noise.
      • 23010
      I've seen quite a lot of polygon mirror motor failures on Sharp, and yes they can be very loud.
      Years back I had a Canon fax L770 at the airport, and each time they printed a reception it sounded just like a 747 landing. They never even noticed. =^..^=
      • ntbann
        • Jan 2012
        • 629
        Ive had success taking the polygon apart and cleaning the shaft and apply some light oil.
        • Prints Charming
          • Aug 2019
          • 189
          This.
          These models are an oil bearing Polygon motor. A very small amount of machine oil on the motor shaft can definitely fix a loud motor. Run LSU load test 61-01 to confirm everything works OK after reassembling.
