Mx4071 u2-40 / a0-19 (30,f5)
  • mansart
    • 852
    [Error Code] Mx4071 u2-40 / a0-19 (30,f5)
    MX4071
    • random u2-40 codes, I get the email alert, customer never calls
    • customer says they have been resetting it by OFF/ON via OP panel switch.
    • Machine no longer resets
    When I replace the eMMC PWB
    • machine will not boot.
    • white screen with error code A0-19 (30,F5)
    • cannot access emergency firmware via dip switch
    When I put the original eMMC PWB back into machine, I can get it to boot to operational ready. Problem is within 24 hours the machine will code out with U2-40
    Any suggestions, welcome
    MFP board next step
  • danceswrabbit
    • Dec 2013
    • 65
    Re: Mx4071 u2-40 / a0-19 (30,f5)
    I was told a good while back that a lot of u codes are power related. Do you have one of those surge protectors that log events?
    • mloudy
      • Oct 2015
      • 787
      So we have had a U2-40 on 4 seperate machines in the series previous to the MX-4071. We replaced the eMMC in each one and the U2-40 never came back.
      Do you think the new eMMC you installed might be bad? Maybe install it in a machine in the shop and see if it boot up.
      • mansart
        • 852
        • mloudy
          • Oct 2015
          • 787
          I am sure you took the recommended precautions? Me either..
          • mansart
            • 852
            • mansart
              • 852
              • mloudy
                • Oct 2015
                • 787
                Now you can sleep tonight without waking up in a cold sweat.
                • mansart
                  • 852
                  As long as I don't look at the numbers on this machine, I'll sleep like a baby.
