I have a Sharp ARBC260 with error F6-20....intravia says "Fax write protect release". I'm new to this model.....can someone help. I've already tried to just clear the code, but no change. Thanks.
F6-20
From the Service Manual:
"Title FAX write protect release
F6 20 Display Lamp/Message
Phenomenon Detail The write protect JP of the
ICU PWB is released.
Section FAX
Case 1) Cause - The FAX write protect pin is
set to Write Enable.
Check &
Remedy
Check the write protect pin
of the ICU PWB.
Case 2) Cause - ICU PWB trouble
Check &
Remedy
Replace the ICU PWB.
Case 3) Cause - FAX PWB trouble
Check &
Remedy
Replace the FAX PWB."
Hope this helps."You can't trust your eyes, if your mind is out of focus" -- -
Based on that little paragraph, I would suspect that someone flashed the firmware recently and did not return the write protect switch to the On position. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
