ARM207 Black lines sending fax's only
  • Passthebiscuits
    • Mar 2009
    • 32
    It has perfectly spaced out black horizontal lines that looks like a lined A4 note pad, but only on sent fax.
    Receives ok
    Tried replacing fax boards and cables
    Checked line and tested with another fax ok
    Scanner seems ok as its copying from adf and glass ok.
    Turned off Ecm tried different resolutions.
    Im thinking it still maybe a fault with the scanner as the process is different to standard copying as it doesn't use grayscale.
    Anyone had this? or suggestions thanks chaps
    • 23006
    Myself, I'm leaning towards a fax card issue. If it was a CCD or image processing related issue, theoretically all scan functions should be affected. If I were to rank by likelihood:
    1) fax card
    2) MCU
    3) CCD
    Have you tried the simple things like reseating all the associated connectors (especially ribbon cables) and cards? =^..^=
    • mtech
      • Mar 2007
      • 307
      Is it scanning the fax into memory then sending or is it sending direct. I had a similar issue on an older Sharp and it was the memory that was causing the issue. If you haven't already, you may also want to clear the fax image memory or an all memory clear after installing the fax pwb.
      • Passthebiscuits
        • Mar 2009
        • 32
        1) fax card
        2) MCU
        3) CCD
        I have replaced as in "fit brand new" fax boards, and fault is still present, I have tried direct faxing also so not a memory issue, and I have resat ribbon cables.
        • mtech
          • Mar 2007
          • 307
          Then as black cat noted, try CCD or MCU. I would go for CCD but that is just my opinion. Good luck!
          • Passthebiscuits
            • Mar 2009
            • 32
            Just a quick reply thanks guys the MCU fixed the fault
            • StormyKnight
              • Dec 2008
              • 50
              May or may not be related to the above issue, but it is always good to understand how faxes work.
              A fax image that is sent contains only white or black image pixels, i.e. no greyscales or halftones. Halftones are created by dithering. i.e. the spacing of black & white dots to make the appearance of a shade when looked at from a normal reading distance.
              For the fax at the other end to understand the image sent, all processing at the sending will end up with these black or white pixels as the result.
              Dirty optics will commonly show more easily on faxing rather than copying for this reason. The grey sections read by the CCD needs to be read as white or black. If it reaches a certain threshold, it will be converted to black. With slit glass scanning this will result in a complete black line on the outputed image.
              Also bad or faulty conversion or processing can also result in black or white artifacts as the conversion process can only ever result in a white or black pixel. I suspect that in this case with the MCU.
