MX-B467P Counter per mail possible ??
  • OlliK1969
    • Nov 2016
    • 311
    Hello.
    Is it possible to get a monthly meter reading automatically with the MX-B467P ? SMTP settings are set up, toner warnings or error messages appear, but we can't find a way to send the meter readings.
    Short feedback would be nice.
    Thanks and Merry Christmas to all
  • mloudy
    • Oct 2015
    • 791
    Re: MX-B467P Counter per mail possible ??
    Settings -> Print -> Job Accounting
    • boutn
      • Jun 2016
      • 551
      Originally posted by OlliK1969
      Hello.
      Try the 'customer support' app.
      We are using this to mail the counters monthly.
      Make sure you have a 'from' address.
      • mloudy
        • Oct 2015
        • 791
        Have you found a way to add the customer support app to this model? I didn't think this model supported apps.
        We have added Custoemr Support to other Sharpmark models that allow USB firmware updates but this model does not have a USB port.
        • mloudy
          • Oct 2015
          • 791
          If you end up using the method I described this is what you will get in an email:
          Model Name; <MN>: SHARP MX-B467P;
          Asset Tag; <AT>: ;
          Serial Number; <ID>: 460012841XD1P;
          Date; <DATE>: 2022/12/22;
          Picked Sides; <PRINT_SIDE_USE_PICKED>: 1; Printed Sides; <PRINT_SIDE_USE_TOTAL_SAFE>: 1; Mono Sides Printed; <MEDIA_SIZE_TYPE_MONO_SIDE_SAFE>: 1;
          Customer Support gives you a much better email layout.
          • boutn
            • Jun 2016
            • 551
            Sorry, thought is was an F
            No customer support on these.
            • boutn
              • Jun 2016
              • 551
              Asset Tag; <AT>: ;
              Can you tell me the settings for this also?
              Do i need to activate logs? And all the other dropdown menus
              • boutn
                • Jun 2016
                • 551
                Still havent got this working...
                The machine doesnt seem to make logs.
                If i click export, print or delete logs, nothing is showing, so it cant mail me anything either...
                • mloudy
                  • Oct 2015
                  • 791
                  I have a MX-B467P sending meters once a month. I just put a MX-B467P on our netwrok to test it so I can make sure I explain the setting correctly. It will take at least 24 hours for the first meter to email.
                  • mloudy
                    • Oct 2015
                    • 791
                    Email with meters was received today using these setting in the MX-B476P:
                    Settings, Print, Job Accounting, Accounting Log Frequency
                    Job Accounting, checked tick box
                    Accounting Log Frequency, Monthly (for testing I set it to Daily)
                    Log Action at End of Frequency, Email Current Log
                    Log Action Near Full, None
                    Log Action at Full, None
                    URL to Post Log: blank
                    E-mail Address to Send Logs: whatever address you use
                    Log File Prefix; blank
                    • boutn
                      • Jun 2016
                      • 551
                      Same settings, no mails received.
                      Also, when clicking on "export, print or delete logs", there are no logs...so if there are no logs, the machine can't mail me any logs i guess
                      This is a machine in production, so it prints daily.
                      Tried it on a second machine, same problem.
                      What am i missing?
                      Can you maybe send me a config export of your machine?
                      Or do i need to enable it in the driver also before i get any logs?
                      • mloudy
                        • Oct 2015
                        • 791
                        Do you have SMTP settings entered in E-Mail -> E-mail Setup?
                        I will get my printer back on my network and export the settings.
