Firmware for MX-6240 request - froze machine
  • teklife256
    • Sep 2012
    • 164
  • Prints Charming
    • Aug 2019
    • 189
    Re: Firmware for MX-6240 request - froze machine
    First level of diagnostics on this symptom would be to remove the network cable, then bootup from main power switch.
    Can you Copy and USB Direct Print when not connected to the client network, as a standalone machine?
    It's booting up correctly, which indicates components are generally OK.
    What Firmware version is currently installed?
    Network problems could definitely cause a locked up machine. Seen that before heaps of times.
    Try laptop with crossover network cable to isolate MFD vs potential Client Network issue.
    • ntbann
      • Jan 2012
      • 632
      Do the newer Sharps need a crossover cable?
      • Prints Charming
        • Aug 2019
        • 189
        No, new MFD & newer laptop combo won't need crossover. I'm just too used to saying it.
        • Jhonjon
          • Sep 2013
          • 208
          Did you find the firmware?! If you need it, I can send it to you. What are the options and your region?
