New BP Squeaks
  • JR2ALTA
    • Feb 2010
    • 2033
    New BP Squeaks
    I've bumped into at least 3 BP color machines (5-10k meter counts) with the same noticeable squeak during the copy process. Shame on me, I wasn't there for the noise so I didn't address them but I am sure I will. But I was curious enough to run diagnostics and heard the squeak during the Transfer Load check.
    Anyone else experience this? I hope it's a quick fix and not a potential bulletin.
  • glimmer1980
    • Aug 2014
    • 105
    Re: New BP Squeaks
    Hi,
    Have u figured out what caused the squeak?
    Regards,
    Ramon
    • iori30
      • Aug 2023
      • 2
      Re: New BP Squeaks
      have you done sim 6-8 for the fuser belt ?
      • glimmer1980
        • Aug 2014
        • 105
        Re: New BP Squeaks
        We have replaced the fuser (because it was necessary) and still we had the squeak. When we tried to use 25-2 seperatly on colours developers we also hear a squeak.
        • OlliK1969
          • Nov 2016
          • 312
          Re: New BP Squeaks
          Hi
          1. Model Name: BP-60C31/60C36/60C45/70C31/70C36/70C45/70C55/70C65, BP-50C26/50C31/50C36/50C45/50C55/50C65/55C26
          2. Subject: APPLICATION OF GREASE
          3. Description: Since the noise may be caused from Process unit when the machine is in operation, Floil grease (GE-676(UKOG-0012QSZZ)) has been applied to the roller shaft of the front side. If the noise is caused from Process unit in the field, please apply Floil grease to the following section. Location of MCR unit(Excerpt from Parts Guide J20 Process frame unit)
          TI CCE2945
          • sandersdad72
            • Nov 2016
            • 15
            Anyone ever find a fix for this? I've got 2 BP's with relatively low meter counts and both have a chirp sound when running transfer load check, even with primary belt unit and all 4 drums removed from machine. Today I replaced the main drive unit on a BP-70C36 and still have the chirp when running transfer load check.
            • ihatefinishers13
              Senior MFP Technician
              • Feb 2020
              • 726
              What about the secondary transfer unit? That runs with the primary, and that's pretty much the only thing left when transfer load runs...
              • sandersdad72
                • Nov 2016
                • 15
                So, I've got an MX-7081 chirping with transfer load and that's after removing all drums, primary and secondary transfer unit. So this morning I'm going to replace the black main drive unit. On the BP-70C31 I removed all drums and primary transfer unit but not the secondary so I'll test that later today.
                • sandersdad72
                  • Nov 2016
                  • 15
                  New Black Main Drive Unit took care of the chirp noise on the MX-7081. Will be testing the BP-70C31 this afternoon with secondary transfer unit removed during transfer load check.
                  • ihatefinishers13
                    • Feb 2020
                    • 726
                    Technically the waste box also drives during that, as the drive motor drives the black drum, black DV, primary transfer, and waste box, but I doubt that's it.
                    • Michko
                      • Sep 2010
                      • 32
                      Charge rollers can make a noise.
                      • Andypraeuner
                        • Jun 2013
                        • 35
                        We have found drum units chirping during the transfer load check.
                        • JR2ALTA
                          • Feb 2010
                          • 2033
                          I made the original post and yes, squeaks are main charge rollers 90% of the time.
                          thanks all
                          • sandersdad72
                            • Nov 2016
                            • 15
                            Update......was finally determined the noise only happens when running Tray 1. Previously, noise happens even with primary and secondary belt units removed, and all drums removed. So, replaced the Transport Drive Unit. Noise was gone. Running from Tray 1, no noise. Running transfer load check, no noise. Lasted 3 weeks before customer called back with noise. Today, removed Tray 1 feed unit and then ran CPFM in Sim mode and it chirps slightly not being under load, but still chirping nonetheless. Considering throwing in another feed unit just for the hell of it.
                            • ihatefinishers13
                              • Feb 2020
                              • 726
                              We've even had a DE15 tandem drive squeak (we've never had to mess with tandem bases), so I'm not surprised it's been so finicky. It's not super humid in there is it? I've seen clutches get rusty before, causing squeaks and misfeeds.
