New BP Squeaks
  • JR2ALTA
    • Feb 2010
    • 2031
    New BP Squeaks
    I've bumped into at least 3 BP color machines (5-10k meter counts) with the same noticeable squeak during the copy process. Shame on me, I wasn't there for the noise so I didn't address them but I am sure I will. But I was curious enough to run diagnostics and heard the squeak during the Transfer Load check.
    Anyone else experience this? I hope it's a quick fix and not a potential bulletin.
  • glimmer1980
    • Aug 2014
    • 105
    Re: New BP Squeaks
    Have u figured out what caused the squeak?
    Regards,
    Ramon
    • iori30
      • Aug 2023
      • 2
      Re: New BP Squeaks
      have you done sim 6-8 for the fuser belt ?
      • glimmer1980
        • Aug 2014
        • 105
        Re: New BP Squeaks
        We have replaced the fuser (because it was necessary) and still we had the squeak. When we tried to use 25-2 seperatly on colours developers we also hear a squeak.
        • OlliK1969
          • Nov 2016
          • 310
          Re: New BP Squeaks
          Hi
          1. Model Name: BP-60C31/60C36/60C45/70C31/70C36/70C45/70C55/70C65, BP-50C26/50C31/50C36/50C45/50C55/50C65/55C26
          2. Subject: APPLICATION OF GREASE
          3. Description: Since the noise may be caused from Process unit when the machine is in operation, Floil grease (GE-676(UKOG-0012QSZZ)) has been applied to the roller shaft of the front side. If the noise is caused from Process unit in the field, please apply Floil grease to the following section. Location of MCR unit(Excerpt from Parts Guide J20 Process frame unit)
          TI CCE2945
          • sandersdad72
            • Nov 2016
            • 7
            Anyone ever find a fix for this? I've got 2 BP's with relatively low meter counts and both have a chirp sound when running transfer load check, even with primary belt unit and all 4 drums removed from machine. Today I replaced the main drive unit on a BP-70C36 and still have the chirp when running transfer load check.
