New BP Squeaks
  • sandersdad72
    • Nov 2016
    • 15
    I'd call it a little humid in there. Another tech spent most of the day there yesterday so I"m gonna wait to hear what they ended up with before deciding the next step. Never chased a damm noise this much before.
    • miller01123@gmail.com
      • Jun 2019
      • 55
      I've seen the pickup roller, drive pack and inner exit unit cause squeaks on new BP machines.
      • sandersdad72
        • Nov 2016
        • 15
        Sample of the noise
        • sandersdad72
          • Nov 2016
          • 15
          #19
          IMG_2308.zip Sample of the noise
          • Hart
            • Feb 2024
            • 411
            #20
            It's the strangest advertisement for software I've ever seen.
            Maybe convert it to MP3 ?
            • sandersdad72
              • Nov 2016
              • 15
              #21
              It's a cell phone file. I had to zip it to upload it. But I just tested it and if you download and unzip, the file will play. Another tech took another transport unit over there yesterday and it was quiet until today when it started up with the same noise.
              • sandersdad72
                • Nov 2016
                • 15
                #22
                Originally posted by Michko
                Charge rollers can make a noise.
                Noise happens even with all drums, primary and secondary belt removed.
                • Squiggy
                  • Jan 2020
                  • 40
                  #23
                  Theres a grounding tab on the exit unit that will squeek. If you remove the front cover(the one you have to remove to get the exit unit out 3 screws)you will see the end of the shaft with the grounding tab. We use machine oil on it.
