AR M236
  • Yadstiks
    • Jan 2023
    • 2
    AR M236
    Please help me sort error F9-10
    • 23003
    Re: AR M236
    F9-10 will be a communication error between the MCU and the Printer PWB. Can parts even be gotten for this model? I doubt it. =^..^=
    • Yadstiks
      • Jan 2023
      • 2
      Re: AR M236
      So should I change the boards?
        • 23003
        Re: AR M236
        Which boards did you have in mind?
        I think the Printer PWB is the most likely. The MCU would be my second choice.
        Did you say replacement boards are available? =^..^=
        • ntbann
          • Jan 2012
          • 628
          Re: AR M236
          release date of 2003.I doubt it. maybe Hytec?
          • lenovos
            • Oct 2012
            • 140
            Re: AR M236
            Try reseating your boards and connectors. Also disconnect network cable and reboot copier. Do the second one first.
            Might be time to upgrade to a AR-M257
