Sharp MX-M5070 growling when feeding paper
  • lenovos
    • Oct 2012
    • 140
    I have noticed on a few of these copiers are noisy or growl when they feed paper. It does not seem to cause a problem and customers are not complaining but it bothers me. On one copier messing with the right side door seems to quiet it down.Not sure if it is drive unit or door related. It sounds like it is struggling to feed paper. I seem to remember a similar problem with paper feed drive units on the MX-M503's. Any comments would be appreciated.
  • copiertec
    • Jan 2016
    • 2211
    Re: Sharp MX-M5070 growling when feeding paper
    A few things to check. ARE-1296.PDF ARE-1314.PDF
    Also, try reseating the right side door as well.
    • lenovos
      • Oct 2012
      • 140
      A few things to check. [ATTACH]56480[/ATTACH] [ATTACH]56481[/ATTACH]
      Thank you I will try that.
