BC260
  • repeatcopiers
    • Sep 2008
    • 591
    BC260
    I have 2 Sharp ARBC260 copiers that have a faint line going vertically on the page every 2 inches. It only happens on black and white, color copy is perfect. I have changed out the fuser, transfer belt, toner/dev cartridge and black drum unit. Any ideas? Thanks, Debi
  • Nachoman4life
    • Oct 2007
    • 212
    lines
    sounds like the toner cart drive gear ngerh1530fcz3, they crack and cart drive stops every time the crack rotates to a certain point, very common
    Where the heck is my spring hook?
    • repeatcopiers
      • Sep 2008
      • 591
      lines
      Thanks so much.
      • Nachoman4life
        • Oct 2007
        • 212
        gave you the wrong number its fcz4, even though they seem to be exactly the same gear
        • repeatcopiers
          • Sep 2008
          • 591
          part #
          Precision Roller does carry both gears under 1 part number. Thanks again.
          • Nachoman4life
            • Oct 2007
            • 212
            no prob had to use one today before responding to your post, you may want to get a few even though they are an updated gear they break frequently, especially if you have a lot of that model. I haven't had to use too many on black, usually on color, but at least if you have smaller arms the black is easy to change. color if you cant squeeze your arm back there you can always come from below in the transfer belt cavity.
