MX-6070 Cycling Power
  • teklife256
    • Sep 2012
    • 164
    Have a MX-6070 that constantly cycles power. The screen remains blank the entire time while the machine boots up and then powers back down. On the SCN-MFP PWB there are 4 LEDs next to the Flash ROM which remain lit while booting up and seem normal. The other set of 8 LEDs just above the mSATA do not appear normal. The two LEDs on the far right flash while the others are off. I have tried changing out the HDD and the mSATA to no avail. Seems like a failed SCN-MFP PWB according to the service manual but I'm hoping someone can help me out with any other ideas before I commit to that.
  • bilyahn
    • Dec 2006
    • 1470
    Re: MX-6070 Cycling Power
    I haven't seen this on this series but in the past this has been caused by bad/corrupt print jobs. Is this connected to your network still? Not very helpful but had to ask.
    Good luck
    Bil
    • mloudy
      • Oct 2015
      • 793
      I would check for a paperclip on the ADF pwb. We have had very similiar issues that turned out to be from a paperclip laying on the pwb.
      • chatkal
        • Aug 2015
        • 47
        Disconnect DSPF from SCN-MFP board, check if it boots.
        • jon jennings
          • Aug 2011
          • 51
          MFP surface mount fuse could be blown. We just replaced an MFP for this symptom.
          • Imprestik
            • Aug 2012
            • 297
            I have had this stacks of times.
            1st thing to do is force it into emergency firmware and redo all firmware. I found if it boots into the emergency firmware screen, forcing the firmware will usually resolve it.
            If that fails, the MFP needs to be replaced.
            • fireater
              Repair God? not quite
              • Apr 2006
              • 253
              Capture.JPGmx6070n? if all the lights are not on the mfp board have you a copy of the led checklist? probably msata dead
              I fix copiers ...Well Sorta
              • teklife256
                • Sep 2012
                • 164
                Originally posted by fireater
                [ATTACH=CONFIG]57175[/ATTACH]mx6070n? if all the lights are not on the mfp board have you a copy of the led checklist? probably msata dead
                That's the same verdict I came to as well. I swapped the mSATA with a known good mSATA and no change. Also swapped the suspected bad mSATA into a second machine and it fired up just fine. It would be helpful if there were more details on the LEDs meaning.
                LED checklist? I have the Service Manual
                • fireater
                  • Apr 2006
                  • 253
                  i guess try swapping mfp/scn board next if you did the dissconnect adf first and it still doesnt work
                  • George Ybarra
                    • May 2022
                    • 13
                    Yes had the Same problem changed out HDD/Rom chip/Sata card, did not fix power loop problem Also could not get passed Loop problem to CN UPDATE Mode for FW Update. turned out to be SCN portion of SCN-MFP PWB. Installed refurbished SCN-MFP PWB from HYTEC and that Solved Problem.
                    Note: be careful when disconnecting and reconnecting Flat Ribbon Cable. Also power source from outlet may have caused the problem in the firstplace.
                    Last edited by George Ybarra; 03-25-2023, 08:44 PM. Reason: addition of reason why problem may have occurred.
                    Copy Whisperer
