MX-4071 maintenance code TA reset?
  • campy
    • May 2012
    • 315
    I tried to do a search for this but I don't understand why I can't search "maintenance code TA" and come up with hits . Anyway I have a MX-4071 with that code and it won't reset. I tried the transfer item counters but it still comes up. The drum counters were already reset recently. Should I replace developer even though the copies are good?
    Also anyone have the service and parts manuals? I have the installation and handy guide.
  • EasyRider
    • Jan 2015
    • 87
    Re: MX-4071 maintenance code TA reset?
    It is the "Maintenance counter (Total)". Reset the color and mono maintenance total counters.
    • campy
      • May 2012
      • 315
      Ok thanks
      • George Ybarra
        • May 2022
        • 13
        Originally posted by campy
        Ok thanks
        I had one that would not reset with a smiley face maint due turned out to be that the firmware was way behind and an FW update got rid of message. .
        Copy Whisperer
        • campy
          • May 2012
          • 315
          Is the firmware a tricky operation on Sharp? Where can I get?
          • ntbann
            • Jan 2012
            • 628
            Nope 49-1 and Login
            • campy
              • May 2012
              • 315
              Originally posted by ntbann
              Nope 49-1 and Login
              I can't login. I'm not authorized Sharp service.
              • George Ybarra
                • May 2022
                • 13
                Does your MX-4071 Have Data Security ?
                Copy Whisperer
                • Craigcul
                  • Aug 2017
                  • 70
                  The developer on this range of machine should never need to be replaced as it renews with each new toner cartridge has some developer in it, the other parts should be replaced at thier end of life as per the 22-06 service printout of the machine.
                  Sent from my SM-A715F using Tapatalk
