Wireless Lan BP-50C26
  • OlliK1969
    • Nov 2016
    • 310
    Hello
    Is there another, cheaper way to retrofit a WiFi module to the BP-50C26 than the expensive BP-EB10?
    Accept every idea with gratitude.
  • bilyahn
    • Dec 2006
    • 1470
    Re: Wireless Lan BP-50C26
    If you really want to do it cheap get a wireless switch and attach the copier to it.
    Good luck
    Bil
    • mloudy
      • Oct 2015
      • 778
      The BP-EB10 is inexpensive. Less than $40 USD.
      • OlliK1969
        • Nov 2016
        • 310
        Sure ??
        440,00 $ is the price
        • mloudy
          • Oct 2015
          • 778
          Yes, I just double checked. Our cost is $36.00
          Perhaps there is a reason is is much higher in Europe. Maybe wireless devices have some type of compliance costs that the EU adds on?
          • lky1978
            • Mar 2009
            • 483
            TL-WA850RE | 300Mbps Wi-Fi Range Extender - TP-Link
            u can try this
            tp-link.com
            • JLSam
              • Jun 2015
              • 605
              Wow, that's interesting!
              We are talking about CPWBN2373FCE1 with PR:BP?
              Our cost is $106!
              Must be nice.
              Also, I agree with bilyahn, wanna do it cheap, get a wireless switch.
              • boutn
                • Jun 2016
                • 540
                You can also take one from an old MX2640 or so and put it in the BP
                • ridgemill
                  • Sep 2017
                  • 183
                  Tried this ourselves, did not work. The BP could not see any networks and could not connect, even with explicit SSID and password entered.
                  Also tried a WiFi module from a CR4 and CR4.5 range, same result.
                  • boutn
                    • Jun 2016
                    • 540
                    Aha, just did the test and indeed, doestn work anymore
                    Thanks for the info.
                    It did work in the CR4.5
                    • mloudy
                      • Oct 2015
                      • 778
                      Our cost is $106!
                      Must be nice.
                      That is the correct part# but is $70.00 cheaper to order as a BP-EB10.
                      • JLSam
                        • Jun 2015
                        • 605
                        Ah! Got you.
                        • Trompeter
                          • 38
                          There not the same. Also different location on the machine to place them (US - left corner below the scanner unit / Europe above the front door behind the cabinet).
                          If you want to use an older version (EB18), that's only possible when you sacrifice the USB-port on the front of the machine.
