E7-03
  • glimmer1980
    • Aug 2014
    • 105
    E7-03
    Hello,
    A customer has a B355W. A couple of months ago the machine gave the code E7-03. We replaced the HDD and the error was gone. Now recently the code E7-03 returned. Does anyone have any ideas.
    Regards,
    Ramon
  • JLSam
    • Jun 2015
    • 605
    Re: E7-03
    Originally posted by glimmer1980
    Hello,
    Regards,
    Ramon
    Looked at my history, every single one of my E7-03's were resolved with replacement of HDD's, SD cards, and in one case MFPC PWB.
    I recommend to replace the HDD with OEM this time, and reflash the firmware using CN Emergency Update. (Just checked Service Manual, look at section 8-2 "D. Update method using emergency function")
    If problem persists, replace the SD card, and perform the CN Emergency update.
    I would confirm that the HDD cable is good condition, I have seen the cables crack the harness holder on the MFPC PWB, and that had to be replaced.
    Good luck.
    • bigdaddyooo
      • Dec 2014
      • 212
      Re: E7-03
      [I have found 2 MFP-pwb with broken red Msata connections. If you push that red wire down it will break the little "shelf" on the MFP pwb. It then doesn't have a good connection from the HDD hence the E7-03
      QUOTE=JLSam;2390393]Looked at my history, every single one of my E7-03's were resolved with replacement of HDD's, SD cards, and in one case MFPC PWB.
      Good luck.[/QUOTE]
      Are you the police? "No ma'am, were musicians"
      • mloudy
        • Oct 2015
        • 787
        Re: E7-03
        I don't think these have a SD card.
        I'd try the HDD, then the program ROM followed by the MFPC pwb.
