sharp mx-m2630 code h4-02
  • clark
    • Sep 2016
    • 109
    I got a brand new sharp mx-m2630 that i just delivered and it gives me the code h4-02, i replaced the thermistor and still the code. the machine only has 1000 pages on it. could i have a bad thermistor from sharp. this machine is new, thanks
  • CroceL
    Sharp / Brother Tech
    • Jun 2020
    • 60
    Re: sharp mx-m2630 code h4-02
    Most likely faulty power outlet.
    Try a different one if possible
    • boutn
      • Jun 2016
      • 537
      Had an MX-5071 recently where we swapped the fuser, ac pwb, pcu pwb, mfp pwb, still got h4-01
      Turned out to be the HL PWB
      • bilyahn
        • Dec 2006
        • 1468
        I get these periodically. I would check your fuser connector. I have heard of pins being damaged out of the box. I also clean the connectors (main body and fuser) with alcohol. Some of the connectors are very tiny spacing (Sharp of course has a special swab [AKA expensive] for these) but I can normally clean them with a regular swab.
        Good luck
        Bil
        • George Ybarra
          • May 2022
          • 13
          If you haven't solved the problem, you can check the belt meandering adjustment to see if the belt hasn't shifted moving away from making contact with the thermistor momentarily causing your "H" Code....... Use-6-8Purpose Operation test/checkFunction (Purpose) Used to check fuser belt meandering operation.Section FusingOperation/Procedure1) Tap [EXECUTE] key.2) When the operation is completed normally, "COMPLETE" isdisplayed
          Copy Whisperer
