Msata MX-4071 Image File Griffin2/Phoenix2 - Hanging after Boot
  • memento
    • Oct 2022
    • 2
    Hi at all,
    I have a Sharp MX-4071 the machine boots normally but it stucks/hanging if I gave some input on the touch.
    I bought a matching msata, it is harder to find these than for the previous Griffin/Phoenix machines because of the half size of the msata.
    Have someone an image file to flash the image to the new msata with hddrawcopy.
    Here it should not matter if Phoenix2 or Griffin2, the firmware are the same for all machines?
    Thanks.
  • lky1978
    • Mar 2009
    • 483
    Re: Msata MX-4071 Image File Griffin2/Phoenix2 - Hanging after Boot
    Originally posted by memento
    Hi at all,
    Thanks.
    As i know, this CR4.5 no longer to use msata. This series using Emmc
    • memento
      • Oct 2022
      • 2
      Yes you are right, but where I can buy a matching emmc drive?
      According to the internet an emmc is a soldered SD card?
      msata is a connector, the pins look similar to those of the emmc, but i have not tested it yet.
      Do you think I can't install these?
      • JR2ALTA
        • Feb 2010
        • 2033
        I've brought many machines back from the dead with a CN update, just checking if you tried that.
