why I have a gray layer over my print ( sharp ar m207)
  • mojood
    • Aug 2023
    • 1
    my copier was fine until suddenly it got broken like this. the drum unit is new but cleaned it again to be sure. it print fine, but it has gray layer over the print. what should I do? is there a way or a code to find where it has a problem?
    IMG-20230729-200405 hosted at ImgBB — ImgBB
    IMG-20230730-160817 hosted at ImgBB — ImgBB
    IMG-20230730-160823 hosted at ImgBB — ImgBB
    IMG-20230730-104207 hosted at ImgBB — ImgBB
    IMG-20230730-160808 hosted at ImgBB — ImgBB
    this links are the pictures of my problem.
    • 23008
    Re: why I have a gray layer over my print ( sharp ar m207)
    Are you using genuine Sharp toner? I suspect not.
    If this happened recently, immediately after installing knock-off toner, I have a suggestion: Buy a cartridge of genuine Sharp toner, install it, and run some prints. The knock-off toner will be gradually depleted, and you image quality should return.
    If this has been happening for a while, and you're using genuine toner, I'd start with a developer change, if developer is still available. Part number: AR-202ND
    I'm honestly surprised how many consumables are still available for a 19yr old copier. =^..^=
    • bilyahn
      • Dec 2006
      • 1470
      I agree with blackcat. Almost positive it will be caused by the DV material. Replace and run your 25-2 command and all should be good.
      Good luck
      Bil
      • lky1978
        • Mar 2009
        • 483
        Looks like MCU board problem.
