5071 fuser noise
  • Tonerkiller
    • Oct 2012
    • 668
    5071 fuser noise
    I have a MX5071 that has been having noises coming from the fuser. Is there a solution to this? Is anyone else having this problem?
  • copiertec
    • Jan 2016
    • 2199
    Re: 5071 fuser noise
    Have you upgraded the fuser drive gear to the new style? CCE-2282 bulletin.
    • tmw
      • Dec 2013
      • 259
      We just had a 4071 fuser making noise. Replacing the pressure roller bearings took care of it. Unfortunately if it's the other bearings, they can't be replaced. (easily)
      • Imprestik
        • Aug 2012
        • 297
        I have this all the time
        It's the fusing belt unit bearings on the MX602FB
        For some reason they just don't last and I have never understood why...
        • timroz
          • Oct 2020
          • 18
          If it sounds like a brief buzz before it prints, its usually the plastic cam gear that applies fuser pressure. I've had luck in the past greasing it but ymmv.
          • Sven94
            • Sep 2023
            • 28
            Hi,
            look at the TR. We often had the problem..
            ( One is german, but you can see the plastic bearing which causes the problem )DEA-5856_CCE2861.pdfDEA-5856_5856_Phoe_Griff_2_Serie_Fixiereinheit_Ger_usche.pdf
            • OlliK1969
              • Nov 2016
              • 310
              Hi
              NBRGP1066FCZZ Plain Bearing 2x
              make terrible noise
