Sharp MX-8081 Error Code
  • AndresM
    • Jan 2016
    • 36
    Hi, I'm working on a Sharp MX-80-81 and I' getting this error code when running simulation 50-22 ( Error Data_Main_M_R_all_with 77)
    Do you have any clue what this error code is for.
    Your help would be greatly appreciated.
    Thank you,
    Andy
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Sharp MX-8081 Error Code
    I would start with transfer belt and cleaning IDC sensors. Fixed my goofy error (similar not sure exact) recently.
    • chatkal
      • Aug 2015
      • 47
      If you finished with steps in the previous post and still have the issue, replace M Developer and run 25-2 (for Magenta only)
      • ihatefinishers13
        Senior MFP Technician
        • Feb 2020
        • 693
        What does a skyshot look like? If it's blotchy, that means that color's DV is old and/or just needs refreshed. Run a 25-2 on that particular color with the toner out, and run 50-22 again after cleaning those ID sensors previously mentioned.
        • AndresM
          • Jan 2016
          • 36
          Thank you, Guys, was the LSU the culprit. This model machine is so sensitive to power fluctuations.
          Thanks'
          Andy
          • iHateSharpFusers
            • Jul 2024
            • 38
            Thanks'
            Andy
            I think I am dealing with this same issue right now.
