71 series models wireless not stable?
  • Hansen88
    • 1068
    Hello, we have lots of 70 series, like 4070 out and the wireless works real well. Mostly in the field we install them wired. While I am working on them in the shop I set them to wireless. With the 71 series machines, every one the wireless goes in and out and I can not connect to them. I have to set them up in shop wired. Has anyone else noticed this issue? Thanks.
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 709
    Re: 71 series models wireless not stable?
    I'm going to assume it's because your network is auto-switching them to the 5ghz band. Had that issue with a customer with old ubiquiti equipment that they no longer had access to change things on, so I had to find a way to wire it. Otherwise, have your office broadcast a separate SSID that's only 2.4.
    • Hansen88
      • 1068
      I will look into it. Thanks
