Co Inquiry about sharp series 4
  • DeepRepair
    • Nov 2023
    • 22
    I would like to know if in these models there is a special menu to change the density of the developer like in the series 3 which was code 80-2
  • bilyahn
    • Dec 2006
    • 1470
    Re: Co Inquiry about sharp series 4
    Sorry but Sharp no longer allows access to these codes. Not for a long time now.
    Bil
    • JLSam
      • Jun 2015
      • 605
      Bil
      I mean, they never did. It was supposed to be a secret. But techs like to talk, and knowledge is disseminated throughout our world. What can we do?
      I'm sure they still exist, but until one of those techs talk, then some of us are SOL.
      Although, except for one use with correcting maintenance meters (because of parts swap), I don't really see the point too much.
      • havokprod
        • Oct 2012
        • 159
        When 80-2 was well known, we use to use DV and sometimes toner from older machines or completely different ( read analogue copiers ) and make it work. With varying results, sometimes the image quality was good to great but the dv would only last 40K-80K. Sometimes the image quality would be ok to bearly passable but the dv life would be comparble to what the service manual said. Any of you old heads remember the Sharp SD-2060/2260/3062? We would use SD-4085 toner in combination with SF-9800 DV. More recently We used SD-860 DV in the AR-M/MX-M 550-620-700 with OEM toner, the DV life we would get if I remember correctly was about 120K-150K the image quality was ok to good. This is what I suspect our OP friend from Mexicalli is trying to do.
        • JLSam
          • Jun 2015
          • 605
          Originally posted by havokprod
          Any of you old heads remember...
          Times like this, I remember I'm probably one of the more younger, but more experienced techs in this site.
          Never dealt with Analog Sharps. Had 1 analog Canon copier stop by, and my boss started sharing his knowledge on it's engineering.
          Oldest models I've worked on are... the ARM355/455, ARM550, ARM207/257s, MX4500/4501/6200/6201...
          Yet, these are the new models for some of the old heads here, lol.
          • havokprod
            • Oct 2012
            • 159
            I got a feeling you and I are about the same age, while you might of been working on the AR/M355 M550 etc as new machines I started with the previous generation machines that happen to be analogues. So is the life of an indy used dealer. The first digital machines I touched were Konicas before the merger 7050/7150 and 7040's.
            • mloudy
              • Oct 2015
              • 790
              SF-741
              SF-9500
              Heck I even worked on memeographs and duplicators. I just turned 55. I started working in this field at 15.
              • JLSam
                • Jun 2015
                • 605
                Could be, I'm 33.
                Originally posted by mloudy
                SF-741
                SF-9500
                Had to google what that was.
                • DeepRepair
                  • Nov 2023
                  • 22
                  Could be, I'm 33.
                  I'm 24 years old
                  • mloudy
                    • Oct 2015
                    • 790
                    We literally have a few copiers out there as old as you. Yikes!
                    • copiertec
                      • Jan 2016
                      • 2211
                      SF-741
                      SF-9500
                      I don't recall working on the SF-741. Was that the tabletop series with masters and a moving platen? But, spent plenty of time on those SF-9500's. We just scraped an AR-337, I literally felt sad to see it being lifted away.
                      • mloudy
                        • Oct 2015
                        • 790
                        You might be thinking of the SF-750. It had a moving table top. The SF-741 used a master also but was a larger table top model.
                        Somewhere I have a large pair of bamboo tongs that were used to reach into the "toaster" fusing area to remove paper jams.
                        • DeepRepair
                          • Nov 2023
                          • 22
                          Originally posted by kevin32305
                          [ATTACH=CONFIG]60862[/ATTACH]
                          Friend, can you help me how to enter?
                          • chubblies
                            • Jun 2011
                            • 155
                            I remember the toaster. Fire extinguisher always close by to the machine in case of excessive fuser jams
                            • havokprod
                              • Oct 2012
                              • 159
                              this picture is interesting.
