Co Inquiry about sharp series 4
  • mloudy
    • Oct 2015
    • 775
    #16
    Re: Co Inquiry about sharp series 4
    Looks like somebody has the secret sim keystrokes....
    • havokprod
      • Oct 2012
      • 159
      #17
      sharing is caring.
      • mloudy
        • Oct 2015
        • 775
        #18
        Sharp USA would NEVER provide the keystrokes to get into these sims. It would be awesome to know how but I would be very hesistant to share it if I knew how.
        Time to start pecking away and video record it until I hit the jackpot.
        • havokprod
          • Oct 2012
          • 159
          #19
          Looks like he is using Remote front panel, correct me if i am wrong but you need the SRDM package to be able to do Remote Front Panel?
          • mloudy
            • Oct 2015
            • 775
            #20
            I think remote front panel is available standard. I've used it many times.
            • DeepRepair
              • Nov 2023
              • 22
              #21
              What I mean is how this simulation contains up to 80
              • mloudy
                • Oct 2015
                • 775
                #22
                I would also like to know how to enter these hidden simulation s. I have no idea how.
                Perhaps a trip overseas is needed.
                • havokprod
                  • Oct 2012
                  • 159
                  #23
                  check your pm mloudy
                  • DeepRepair
                    • Nov 2023
                    • 22
                    #24
                    I also want to know how to access that simulation in sharp mx364
                    • DeepRepair
                      • Nov 2023
                      • 22
                      #25
                      Originally posted by kevin32305
                      you need a secret key
                      special Msata
                      Where can I get it ?
                      • JLSam
                        • Jun 2015
                        • 605
                        #26
                        [ATTACH=CONFIG]60862[/ATTACH]
                        Well well well well well...
                        That is indeed interesting.
                        Kevin my good man. Sharing is caring.
                        • DeepRepair
                          • Nov 2023
                          • 22
                          #27
                          But does it work on a sharp series 4?
                          • DeepRepair
                            • Nov 2023
                            • 22
                            #28
                            only CR4
                            change Msata
                            I can only help you so far
                            Let me see if I change the msata and install the file you sent
                            • mloudy
                              • Oct 2015
                              • 775
                              #29
                              So that file download was large. It is an .img and not an .imgc file like all of the other msata images I have seen. I asked our IT tech about the difference and he wasn't sure.
                              I am going to try and burn it to an msata and see what happens.
                              • dannyfor
                                • Dec 2023
                                • 5
                                #30
                                In the Sharp Series 4 models, there is a menu to adjust the developer density. You can find this option in the settings menu typically under the maintenance or calibration section
