Sharp MX2310u error code
  • Countrykez
    • Dec 2023
    • 5
    [Error Code] Sharp MX2310u error code
  • CroceL
    Sharp / Brother Tech
    • Jun 2020
    • 62
    Re: Sharp MX2310u error code
    Problem with the Scanner unit / mainboard
    Easiest thing you can try yourself is an error reset.
    Start up the machine
    Look if you're in copy mode in the top left corner (Just ignore the error code window)
    Press # * C #
    Service mode should pop up
    Press 1 4
    Press B/W or Color Start button
    Bottom right corner on the display select "Execute"
    Bottom left corner on the display select "Yes"
    Press CA on the keyboard
    Machine should restart with "Simulation finishing etc.."
    Error gone good, error not gone call someone or open up the MFP top-backside yourself.
    From personal experience I mostly had this error in container offices in the winter when the mice where coming in and chewing on the cabel from the Scanner Mainboard.
    • ron67601
      I think he meant to tell you #*C*.
      • chatkal
        • Aug 2015
        • 47
        Application specific integrated circuit - ASIC.
        Charge-coupled device - CCD.
        It's the chip and circuit on the right side of the flatbed scanner, under the glass.
        In many many cases this error caused by a metal paper clip or a staple on the DSPF board.
        • Countrykez
          • Dec 2023
          • 5
          • Countrykez
            • Dec 2023
            • 5
            Originally posted by Countrykez
            [ATTACH=CONFIG]60882[/ATTACH]
