Sharp-MX-C507F "Incompatible settings were selected" error message
  • Roadie
    • Jul 2023
    • 3
    [Error Code] Sharp-MX-C507F "Incompatible settings were selected" error message
    Hello all,
    I've got a weird issue with this Sharp-MX-C507F. Anytime a document is scanned to a network folder this error message comes up on the OP panel: "Incompatible settings were selected. Some settings have been modified. Do you want to continue with the job?"
    We've checked and updated drivers and firmware, double and triple checked driver and settings, deleted network scan profiles/location and created a new scan folder on the workstation. I even did a reset to factory settings and a fresh setup. Still getting this message with each scan. Sharp Tech support is stumped and has only recommended what we've already tried. The message doesn't prevent scanning or cause any other issues with scan output, etc., but it is annoying for the customer. I was hoping you folks might have some suggestions on how to resolve. Thanks!
  • mloudy
    • Oct 2015
    • 790
    Re: Sharp-MX-C507F "Incompatible settings were selected" error message
    Have you hit the internal service web page on this machine and looked through any of the log files? There are also many other things in there that might help you track down the reason for the message you are getting.
    • Roadie
      • Jul 2023
      • 3
      Thanks for the suggestion, I will have a look!
      • WackyJack
        • Feb 2021
        • 82
        Have you tried asking on the Lexmark forum? The Lexmark model number is XC4150
        • mloudy
          • Oct 2015
          • 790
          Our IT tech has seen this. He thinks it had something to do with a default tick box being checked in the scanning setup. Maybe flatbed scanning?
