SHARP MX M7570 Noise on fuser
  • txonsov2
    • Aug 2023
    • 18
    I have a problem with a M7570 machine, it makes a noise when moving the fuser with the FUM motor in simulation and when printing, but it is not constant or always the same noise makes it random especially early in the morning is stronger and then softer, I changed the fuser and checked the gear and are healthy. Thank you very much
  • Massimo
    • Feb 2023
    • 22
    Re: SHARP MX M7570 Noise on fuser
    Hai cambiato anche i teli di pulizia hot roller e pressur roller ?
    • JLSam
      • Jun 2015
      • 605
      Look at this>>> Comments are still valid for the monochrome models.
      I would start with... have you replaced the fuser?
      • Hansen88
        • 1068
        If the machine has sat for any length of time or the fuser that you replaced it with has, the lower fuser roll may be flatspotted and on that machine it makes a lot of noise. Any fusers we have on shelf we un pressurize the rollers to prevent flatspots.
        • txonsov2
          • Aug 2023
          • 18
          i replace fuser ,yes!
          • txonsov2
            • Aug 2023
            • 18
            The roller is ok the melter had the tension rollers so that it does not exert pressure
            • txonsov2
              • Aug 2023
              • 18
              i replace de fuser unit complete!
