List of Sharp softswitches
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 715
    Over the last 9 years as a Sharp certified tech, we've been told that no one person has the list to every soft switch on a Sharp MFP - besides .
    I'm here to tell you that........I still don't have that list, I'm just looking to see what switches everyone has found useful?
    We change a couple for VOIP settings from 3 separate bulletins, as well as Address Hold, and toner alert settings.
    But what else ya got?
  • JLSam
    • Jun 2015
    • 605
    Re: List of Sharp softswitches
    My favorite soft switch setting that has saved us $$ on the phoenix 1/2 models is: Sim 55-1, SW 32, Changing Bit 7 from 0 to 1.
    Every 1K, 1 fuser cleaning page.
    Needs the latest firmware.
    • havokprod
      • Oct 2012
      • 159
      These are the ones I have been able to compile from Bulletins and from this site. Equipment im working on is MX-Mxx3, MX-Mxx5, MX-Mxx50/70, MX-xx40, MX-xx50/70
      55-3 sw22 bit 5 from 0-1 shows toner guage
      55-3 sw22 bit 6 from 0-1 cancels DK,DC,DM,DY Stop Drum Maintenance
      55-3 sw27 bit 2 from 0-1 cancels VK,VC,VM,VY Stop Developer Maintenance
      55-3 sw27 bit 3 from 0-1 cancels FK1 & 2 Stop Fusing Unit Maintenance
      55-3 sw27 bit 4 from 0-1 cancels TK1 Stop Primary Transfer Unit Maintenance
      55-3 sw27 bit 5 from 0-1 cancels TK2 Stop Secondary Transfer Maintenance
      55-3 sw34 bit 1 from 0-1 cancels TK3 Stop Primary Transfer Discharge Maintenance
      55-3 sw34 bit 2 from 0-1 cancels MCK,MCC,MCM,MCY Stop Drum Charge Unit
      55-1 sw09 bit 8 from 0-1 Set Maintenance Cycle to prints instead of revolutions/turns
      55-1 sw06 bit 1 from 0-1 Set network speed to manual
      55-1 sw06 bit 4 from 0-1 Set speed to 100mb/s
      Sim 66-01
      sw 108 bit 8 from 0-1 Turns On Digital line net setting -15dBm
      sw 103 bit 6 from 0-1 ECM is turn Off (error resend)
      sw 27 bit 4 from 0-1 V.34 TX is disabled
      sw 27 bit 5 from 0-1 V.34 RX is disabled
      sw 29 bit 3 from 0-1
      sw 29 bit 4 from 0-1
      Used to set TX speed to V.17 14.4kbps
      sw 29 bit 5 from 0-1
      sw 29 bit 6 from 0-1
      sw 29 bit 7 from 0-1
      Used to set RX speed to V.17 14.4kbps
      sw 29 bit 8 from 0-1
      Please share any comments
      • boutn
        • Jun 2016
        • 549
        SIM ITEM SW DATA OP OMSCHRIJVING
        ALL 21-1 999 A en B - cancels TA + CA
        ALL 26-35 A : : 1 any error
        ALL 26-38 B : : 0 maintenance life over 0
        BP-modellen 26-29 AUTO UPDATE
        MX-3060/3070/3570/4060-70/5070-6070 55-01 1 4 1 polygon motor
        MX-3060/3070/3570/4060-70/5070-6070 55-01 9 8 1 Set Maintenance Cycle to prints (Instead of revolutions)
        MX-C300P 55-3 2 7 1 toner MIB report 5%
        ALLE 55-03 3 7 1 HP compatibility mode
        MX-3060/3070/3570/4060-70/5070-6070 55-03 4 7 1 Custom paper size tray1 on Phoenix(2)/Griffin(2)
        MX-B350P MX-B450P MX-300P 55-3 8 8 1 Machine unable to wake up from sleep mode
        ALLE 55-03 9 5 1 Allow printing when maintenance Due
        ALLE 55-03 22 5 1 Show toner icons on screen
        ALLE 55-3 27 2 1 cancels VK VC VM VY notification
        ALLE 55-3 27 3 1 cancels FK123 notification
        ALLE 55-3 27 4 1 cancels TK2 notification
        ALLE 55-3 27 5 1 cancels TK1 notification
        ALLE 55-03 28 3 1 errors 1x mailen
        MX-3060/3070/3570/4060-70/5070-6070 55-03 30 3 1 Retain destination address
        MX-3060/3070/3570/4060-70/5070-6070 55-03 32 2 1 toner MIB report 5%
        ALLE 55-3 34 1 1 cancels TK3 notification
        ALLE 55-3 34 2 1 cancels MCK MCC MCM MCY notification
        MX-3060/3070/3570/4060-70/5070-6070 55-03 34 3 1 USB print PDF files
        MX-2630/3060/3070/3570/4060-70/5070-6070 55-03 44 2,3 1 Blank page skip disable confirmation message
        MX-2630/3060/3070/3570/4060-70/5070-6070 55-03 48 all 0 set trays via webpagina
        MX-3060/3070/3570/4060-70/5070-6070 66-01 95 7 1 Blank page skip disable cancel if confirmation is not pressed
        • boutn
          • Jun 2016
          • 549
          and these ones:
          55-3 45 1 1 cache user info (365) in device account modus
          55-1 32 567 001 = 1K / 010 = 5K / 011 = 10K AUTO FUSER CLEANING PAGE
          • pdy-pt
            • Mar 2018
            • 58
            Does anyone know for what SW 35, Bit 1 is good for?
            • Sven94
              • Sep 2023
              • 30
              To list all Error codes. But i don't know, if that was for the old copiers.
              • Hart
                • Feb 2024
                • 421
                sims.pdf
                • articcat182
                  • Nov 2014
                  • 24
                  Sim 66-01
                  We also change on 66-1 SW 114 Bit 8 to 0 (Turns off external phone line)
                  • pdy-pt
                    • Mar 2018
                    • 58
                    Is there also a way to stop the energy-saving button from flashing (e.g. so that it lights up continuously instead of flashing)? Some people who sit with their desk directly in front of the MFP are driven mad by this
                    • Hart
                      • Feb 2024
                      • 421
                      Put some tape over it.
                      • tsbservice
                        Field tech
                        • 8029
                        [ATTACH=CONFIG]61639[/ATTACH]
                        Yeah like MIL in your car, put some tape on it and it's solved. Doesn't work that way though.
                        • Hart
                          • Feb 2024
                          • 421
                          Really not comparable, the light is not something that need fixing.
                          The other solution is to put the copier into deep sleep, with the light on but not flashing.
                          • ihatefinishers13
                            • Feb 2020
                            • 715
                            That's like the customer who said that the machine was too loud (MX4141, just idling runs a fan, barely noticeable in a regular office). The office was completely silent otherwise... I told them to turn on a radio or white noise machine, there was nothing we could do ha.
                            • Sask1967
                              Senior technician
                              • Jun 2023
                              • 7
                              Hi there, question for VOIP, what is the issue with VOIP before you changed on soft switch settings? and what switch is it? Thanks.
