Sharp MX-4070V
  • holmesm
    • Dec 2023
    • 7
    Sharp MX-4070V
    I have a Sharp MX-4070V that has error code E7-A7. I have tried to update the firmware through the Sim and CN method with no success. I do not have a backup of the mSata and am having an issue finding a pre-programmed one. Does anyone have an image or a suggestion?
  • chubblies
    • Jun 2011
    • 155
    Re: Sharp MX-4070V
    Dropbox - 3570.imgc - Simplify your life
    • holmesm
      • Dec 2023
      • 7
      Re: Sharp MX-4070V
      Originally posted by chubblies
      Worked perfectly - thanks a million!
      • pdy-pt
        • Mar 2018
        • 58
        Re: Sharp MX-4070V
        Could the mSATA image also be used for a Sharp MX-6070N?
        • ihatefinishers13
          Senior MFP Technician
          • Feb 2020
          • 709
          Re: Sharp MX-4070V
          I don't believe so, however, I'd love to know for sure if someone wants to try
          It's basically the exact same machine, but there definitely are some minor electrical differences, so that could be sketchy.
          • Delta-T
            • Mar 2024
            • 2
            Re: Sharp MX-4070V
            Hello, Greetings from Berlin, Germany.
            We have a Sharp MX-4070N
            On Startup it shows the Error E7-A7.
            I checked status of the green LED lights.
            All (the 2x 4 LEDs close to MSATA and the 4 LEDS at the bottom) do shine, no blinking.
            I removed the MSATA, on Startup, the machine seems to loop restarting without Display/Touch Panel turning on.
            I bought an USB adapter, in Windows 10 the disk utility shows many Partitions, all with free Space.
            Crystal Diskinfo shows blue status of the MSATA Disk.
            I am just a friend/simple user in the Office.
            I fear their are no backups of the SHARP MX-4070N.
            Can You please suggest me the next steps?
            I may get a tool to clone the MSATA/Partitions.
            I actually do download Your provided Image from Dropbox.
            Thank You very much.
            Will await some helpful Responses from You folks.
            Anyway I will get me a new 16GBYte MSATA Disk and try two write the Image.
            Almost Midnight in Berlin.
            Good Night.
            Regards Federico Valdez
            • Delta-T
              • Mar 2024
              • 2
              Re: Sharp MX-4070V
              All is fine.
              RAW Copying an Image of the defunct MSATA shows 0,5 MB/s - canceled.
              Writing 3570.imgc to new MSATA Disk , 50 MB/s. finished all right.
              MX-4070N does start as usual.
              We are glad.
              Thanks to the folks in Copytechnet.co for providing Information / Image file.
              Federico
