sharp mx3050 jamming
  • clark
    • Sep 2016
    • 109
    I have a sharp mx3050 copier. The machine jams at the registration roller assy. It does throw up a code. But they have been clear out. It does this thru out the day. No jam. Just feed the paper up to the registration roller assy and runs for a minute. the panel is stuck on the display that its coping the page. I replaced sensors by the roller assy. replaced the sensor there. Any help would be nice. Thanks
  • Hart
    • Feb 2024
    • 377
    Re: sharp mx3050 jamming
    56-05 to export the data to an USB stick then publish it.
    What happens if you put the copier in aging misfeed 7-1 ?
    • bilyahn
      • Dec 2006
      • 1470
      I had this happen on a 4071. jams with no jam code listed then it would code out with an H5-01 error. Replaced the POD1 sensor and all was good.
      Good luck.
      Bil
      • hellcat
        • Jan 2012
        • 124
        yea ive had to replace a few pod1 sensors on these as well, I believe there was a tech bulletin back in the day on them.
        • tedtech
          • Dec 2011
          • 50
          If it's sitting there at the reg/ps roller, check the log for pri_jam. That would be the HDD because its trying to process the job and it will wait there for the data.
          • clark
            • Sep 2016
            • 109
            Thank you. That makes since.
