sharp mx 6580
  • AMS
    • Jun 2017
    • 73
    sharp mx 6580
    I have one with a blank display. The paper trays will not lift and cooling fans run and will not print. mSATA was replaced and lcdv pcb was replaced. per tech help from another sharp dealer.. We are mainly a Ricoh dealer and our customer had this sharp copier they wanted us to look at. Any help with this would be appreciated. Thanks
  • ron67601
    Re: sharp mx 6580
    Sounds like it won't boot up. Did you check the lights on the MFP Board? Does your green power button blink or is it solid?
    • AMS
      • Jun 2017
      • 73
      Re: sharp mx 6580
      yes there are lights on the mfp and the start button blinks
      • Mint325
        Hybrid Tech
        • Feb 2016
        • 17
        Re: sharp mx 6580
        Was the blank screen the original symptom or is this a new symptom after replacing the two parts? Based on your description, it sounds like your device had been hit with electrical issue on site prior to your service visit.
        Ricoh Technician for 6 Years
        Sharp Technician for 3 Years
        Dabbled in Canons, Brothers, HPs, Lexmarks, FPs. etc
        "If I can glue it; I can fix it."
        • chubblies
          • Jun 2011
          • 155
          Re: sharp mx 6580
          Check the flywheels have not fallen off and taken out the power supply. There is a bulletin regarding this
          • ihatefinishers13
            Senior MFP Technician
            • Feb 2020
            • 715
            Re: sharp mx 6580
            I could be wrong, but the doc feeder is the same style a lot of others.... Take off the rear cover, and check for paper clips/staples/other metal that could be sitting on the board.
