MX-M 7570 Web timing
  • Hansen88
    • 1084
    Hello, I have been back and forth in the manual and having trouble finding how to change the web advance setting so it advances more often. I have done it before, cant find setting now. If anyone can help I would sure appreciate it. By the way, I am fighting jamming in the fuser on multiple machines of this model.
  • mloudy
    • Oct 2015
    • 791
    Re: MX-M 7570 Web timing
    Check 43-24 item C
    We had to remove the upper fuser web from one of our MX-M7570 in a school. It was not advancing like it should and making noise and causing jamming. All the other ones have been running without issues with the web.
    • Hansen88
      • 1084
      Originally posted by mloudy
      Check 43-24 item C
      Thanks, I found that one, I was not sure if it was right. It looks like it makes the motor run longer or shorter time. I will try this, but what I was trying to find, maybe dont have it, is to make the web activate more often.
      • ihatefinishers13
        Senior MFP Technician
        • Feb 2020
        • 726
        Maybe useful?
